1992 Pontiac Bonneville Oil pressure gauge
1992 PONTIAC BONNEVILLE
198,000 MILES • 6 CYL • FWD • AUTOMATIC
DADO RICK
Oil pressure dash gauge reads 40 psi when cold. Warm is very close to zero causing the audible warning and "check gauges" light. Manual gauge shows 60 cold and 15 warm, installed new sending unit with no help. Any suggestions?
Nov 11, 2009 at 5:13 PM
Do you hear any type of bottom end knock if not could be the oil pump pressure relief valve or engine bearings
Nov 11, 2009 at 5:38 PM
