Engine Performance problem
1991 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
have a boniville that sents code 41 already replaced cam magnet new cam sensor new crank sensor tried 3 diffrent ignition modules has signal out of crank sensor can generate signal into ecm when bypassing the ignition module and no code sets checked all wiring replaced pig tail to cam sensor when running or key on the signal wire has 12 volts on it cut wire to pcm and pcm side doesn't have voltage onit
May 7, 2009 at 2:07 PM
