1990 Pontiac Bonneville idle air control motor
1990 PONTIAC BONNEVILLE
65,000 MILES • 6 CYL • FWD • AUTOMATIC
BALLD72
The plunger on the iac motor runs in and out with the ignition off. I heard a noise under the hood, pulled the iac and found the plunger going in and out. Now what???
Aug 28, 2009 at 7:40 PM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_bonnIAC_1.jpg
1. Disconnect harness connector to motor. Check resistance across IAC coil terminals "A" to "B" and "C" to "D". Resistance should be 40-80 ohms. See Fig. 12 . If okay, go to next step. If resistance is not as specified, replace IAC motor. 2. Check resistance between IAC terminals "B" to "C" and "A" to "D". Resistance should be infinite. If resistance is not as specified, replace IAC motor.
Aug 28, 2009 at 7:46 PM
