1975 Pontiac Bonneville
1975 PONTIAC BONNEVILLE
95,000 MILES • V8 • 2WD • MANUAL
GRANDVILLE400
my 1975 pontiac 400 cu in is overheating i hace replace the thermostat hoses and waterpump the car has been sitting for some time and when i drained the radiator it looked like mud i flushed rad several times and stilll after running the car the coolant looks like mud should i replace the radiator or do i have more serious problem
Aug 17, 2009 at 11:49 PM
Flush it real good and get that muddy out and make sure you bleed the cooling system if it continues get it block and pressure tested to rule out a blown headgasket cracked head or block-
Aug 17, 2009 at 11:56 PM
