check brake light and brake light switch
Gearshift lever cannot be moved from "P" position without simultaneously applying brake pedal with ignition switch turned to ON position. When brake pedal is applied, brakelight switch completes or interrupts circuit to BTSI solenoid. Depending upon application, energizing or de-energizing BTSI solenoid unlocks gearshift lever from "P" position
Transaxle/Transmission shift interlock system prevents driver from moving gearshift lever from "P" position unless ignition switch is turned to ON position. On models equipped with Brake Transmission Shift Interlock (BTSI) solenoid, gearshift lever cannot be moved from "P" position without simultaneously applying brake pedal with ignition switch turned to ON position. Shift interlock solenoid is located at gearshift lever in steering column or center console.
Apr 9, 2020 at 12:57 PM
(Merged)
