Can I reset the computer myself or do I need to take it in?
Jun 28, 2020 at 11:26 AM
(Merged)
SATURNTECH9
CERTIFIED EXPERT
When you say reset the computer what are you referring to? Also, why are you trying to do this?
(Merged)
BJOENFINGER
MEMBER
I replaced the ignition. Now it acts normal until you try to start it and then nothing. Everyone I talked to said the computer needs to be reset. I do not know.
(Merged)
SATURNTECH9
CERTIFIED EXPERT
You need to relearn the pass lock sensor. Try starting the car then let the key go back to the "run" position do not turn it back any further. when the security light stops flashing and or turns off most of the time it will turn off usually about ten minutes.Then repeat that two more times a total of three times it should start. Before you start make sure the battery is fully charged and that you have a good battery. Turn off all lights day time running radio AC fan etc. Let me know how it goes.
(Merged)
BJOENFINGER
MEMBER
I will try tomorrow. Thank you very much!
(Merged)
SATURNTECH9
CERTIFIED EXPERT
You are welcome we are here to help. so you replaced the whole steering wheel lock housing with the cylinder?
(Merged)
BJOENFINGER
MEMBER
Yes and did the reset to security. That light don't come on but still nothing when you try to start.
(Merged)
SATURNTECH9
CERTIFIED EXPERT
So the security light isn't on solid or flashing with the key in the Run position?Also the starter is inop?If so have you checked for any blown fuses?
(Merged)
BJOENFINGER
MEMBER
It's on and won't come off. Some times it takes a few minutes to come on. Yes I checked all the fuses. Do you know if you can bypass the pass lock 3? I've seen on YouTube where others have with different gm cars?
(Merged)
SATURNTECH9
CERTIFIED EXPERT
So how did you try to relearn the pass lock please tell me step by step how you did it?Also we don't give instructions on how to bypass any kind of security systems
(Merged)
BJOENFINGER
MEMBER
Turn the key on until security light goes away or stops flashing it never goes away. It's says takes ten to 11 min. I did both and longer. Turn to off position wait five seconds then repeat three more times.
(Merged)
SATURNTECH9
CERTIFIED EXPERT
OK when you you say you turned the key on did you turn the key to the start position and then let it go back to the Run position without turning it off and let it sit in the run position for ten minutes till the security light turns off then turn the key off for ten seconds and repeat that for a total of three Times?
(Merged)
BJOENFINGER
MEMBER
Yes several times it don't go out
(Merged)
CERTIFIED EXPERT
Hey Bjoenfinger,
Is sounds like the chip in the new key will need to be reset by the dealer. Anytime you put a new key a tumbler this will need to be done.
Please let us know what you find so it will help others.
Best, Ken
(Merged)
BJOENFINGER
MEMBER
Thanks for your help but looks like I just junk it and take it as lesson learn avoid Pontiac.
(Merged)
CERTIFIED EXPERT
With Only 100,000 miles I would call the dealer and ask how much, cant be that bad. A different car will have problems too.
(Merged)
BJOENFINGER
MEMBER
But what I keep reading it's a on going problem with Pontiac/gm. I'm not going keep towing it to the dealer. For security issues. I'm gonna try bypassing it this weekend if that doesn't work. I rather cut my losses. But I really appreciate all you help and suggestions tyvm
(Merged)
SATURNTECH9
CERTIFIED EXPERT
So why don't you have the new cylinder keyed to your old key so the car will start?
