recently ; my car have problem with brake system ,the pad from brake system keep closed to rotor ; make it hard to move and have vibrate the turning wheel ; And I doubt it have problem with brakes caplier or bleed fluid system have moisture or air with it then What I should do about it ? change brake caplier or chang new brake fluid system ; if change brake fluid system ;how change it properly by bleed the fluid brake system correctly; Please help me the question seem long and complex but with your professional may be have the idea about it.
Thanks you very much .
Jun 7, 2009 at 2:50 AM
