Strong oder of gas, but no visible leaks and it does not appear to be using an abnormal amount of fuel
Dec 1, 2008 at 12:03 PM
JAMES W.
CERTIFIED EXPERT
Check your fuel pressure regulator. there is a vacuum line attached to it. Pull the line off and look for fuel in the vac. line. If you, replace the regulator.
