The problem seems to come and go. The vehicle will run great for a day or two, then it'll start acting up again. I put on a new fuel filter and had about the same pressure readings. I then had new plugs and wires installed. That seemed to help for about a day. The "Service Engine Soon" light always comes on when it's running rough. And it flashes often too, indicating a misfire. Two different mechanics confirmed it was misfiring on cylinder 1. I then had my fuel system and injectors cleaned. It ran great after that.... for a few days. Last night, I sprayed down the MAF with some special MAF cleaner. That didn't help either. I also misted the engine with water to check for arcing, but didn't see any. Could it be the coil pack? Help please!
Aug 21, 2010 at 12:02 PM
