2002 Pontiac Aztek ANSWER TO "CAN'T GET KEY OUT,"
2002 PONTIAC AZTEK
61,000 MILES • 6 CYL • AWD • AUTOMATIC
TOMPROUDFOOT
The will get stuck in the ignition IF there is low or no battery power to the ignition switch. It happened on mine and was fine with the replacement of the car battery. TOM
Nov 17, 2008 at 1:07 PM
TOMPROUDFOOT
The KEY will get stuck in the ignition IF there is low or no battery power to the ignition switch. Check the battery cables and connectors and the car battery for proper connection and/charge. It happened on mine and was fine with the replacement of the car battery connectors. Also the problem could (though I doubt it) be the computer. When it happened on mine, the rear hatch would not open and AC did not work. Hope it helps! TOM
Nov 17, 2008 at 1:15 PM
