You will have to remove the door panel and inspect the window regulator it is most likely broken and that is why the window came off track.
Oct 25, 2010 at 11:56 AM
TACTICALTONYA
MEMBER
NEED STEP BY STEP NOT SURE HOW CABLES GO BACK IN TO GET IT BACK ON TRACK
Oct 25, 2010 at 12:24 PM
SATURNTECH9
CERTIFIED EXPERT
If the cable's came out then the window regulator broke and need's to be replaced.I found a regulator and motor for 76 plus shipping.
Oct 25, 2010 at 12:31 PM
TACTICALTONYA
MEMBER
CAN YOU SEND ME AN ILLUSTRATION OF THE ASSEMBLY INSIDE OF THE DOOR-i REALIZE THAT IT MIGHT BE BROKEN AS A MATTER OF FACT THE SMALL PLASTIC GUIDE IS BROKEN...CAN i GET JUST THE PLASTIC GUIDE WITHOUT BUYING THE WHOLE ASSEMBLY?
Oct 25, 2010 at 12:41 PM
SATURNTECH9
CERTIFIED EXPERT
That's the only diagram i have for the window regulator.When stuff start's breaking on the window regulator's all you can really do is to replace the regulator they don't make many thing's these day's that are repairable.We live in a throw away world if you want to know where to get that regulator i will even give you my 5 percent discount code they gave from ordering from them i have bought a lot of stuff from them.
Oct 25, 2010 at 12:58 PM
TACTICALTONYA
MEMBER
THANK YOU SO MUCH FOR YOUR HELP - I WILL LET YOU KNOW IF I AM GONNA PURCHASE WHOLE ASSEMBLY
Oct 25, 2010 at 1:32 PM
SATURNTECH9
CERTIFIED EXPERT
Alright keep me posted.
Oct 25, 2010 at 2:22 PM
GMTECH
CERTIFIED EXPERT
There is a GM product service bulletin about this problem. You can buy just the guide to repair without buying the whole regulator. Here is the P/N Front 15286776 and Rear 15286777
Nov 14, 2010 at 9:38 AM
ASARRIAGA
MEMBER
1 POST
This is the exact problem I'm having too! I cannot find these service bulletins anywhere online or GM's website. I've contact GM, waiting for an answer. Next step I'll go into a dealership but was just wondering if you know where I can get this bulletin at? Thanks.
