2001 Pontiac Aztek slow death
2001 PONTIAC AZTEK
LOSTKISS
Computer problem
2001 Pontiac Aztek Front Wheel Drive Automatic
the car will start one day with nothing on the dashboard lit up and working except the fan/ac/heat. the lights will work manually. witin 24 hours the car is dead, unhooking the battery or jumping will restart ,it and she goes for about 3 weeks before repeating. last night i got in the car had no lights i turn the key first the service engind lights came on , then the fan with a click and whiring sound from the engine for a few seconds. the dash lights came on then everything died. My mechanic is going nuts as am i.
Nov 19, 2008 at 1:08 PM
Have him make sure the charging system is working properly and the battery passes a load test. Also, check and make sure all grounds are clean and tight. Finally, has he scanned the computer for codes? There may be a problem with the BCM.
Nov 26, 2008 at 7:45 PM
