2001 Pontiac Aztek heater core replacement
2001 PONTIAC AZTEK
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
POOB12
While driving the windows fog up , but the heater is working, if it is the core how hard is it to replace it and where would be the best place to go. Can it be managed with a used core instead of a new one
Nov 20, 2008 at 1:47 PM
Hi:
The heater core may have a small leak. It will still work, but you will loose coolant and it can cause the window to fog. To replace it, you need to remove most of the dashboard. It's not a fun job. I woud get a new one rather than used. It's too much work to do it twice.
Nov 26, 2008 at 7:41 PM
