2001 Pontiac Aztek car will not start
2001 PONTIAC AZTEK
179,000 MILES • 6 CYL • 2WD • AUTOMATIC
we changed the starter. The car still will not start. It acts like it is going to start but will not turn over. what else could be the problem?
Jun 23, 2010 at 8:54 PM
Lets do below for a start to determine if its fuel or spark related issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 23, 2010 at 8:58 PM
