1991 Pontiac 6000 egr valve
1991 PONTIAC 6000
156,000 MILES • 6 CYL • FWD • AUTOMATIC
RED_WING45
  • 33 POSTS
hi can i clean a egr valve or can i use a used one.
Jul 30, 2009 at 11:05 AM
JMALECKI
  • 118 POSTS
Hello
Depending on what is wrong with the egr valve you may be able clean it if it has carbon build up, clean with carb cleaner. You can try a used valve, but many times you end up with one as bad if not worse than the one you are replacing.
John
Aug 19, 2009 at 6:44 PM
