1987 Pontiac 6000 Trouble starting
1987 PONTIAC 6000
11,000 MILES • 4 CYL • FWD • AUTOMATIC
DARRYLCOMBS
When I start the car the first time there is no problem. After driving 20 miles or so and I shut it down to go into a store and it is off for 15 to 30 minutes it doesn't want to start. If I let it set for a while 15 -20 more minutes it starts right up, usually. Sometimes it will start but sounds as if it is having trouble getting gas, when this happens it usually stalls out,unless I can rev the engine up until it smoothes out. But from a cold start is turns over and starts right up. Fuel pump or fuel filter?
Jul 8, 2010 at 12:35 PM
Next time it refuses to start don't wait for nothing do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 8, 2010 at 2:28 PM
