1987 Pontiac 6000 tail lights and turn signal lamps
1987 PONTIAC 6000
41,000 MILES • 6 CYL • 2WD • AUTOMATIC
MISTRAL
MEMBER
1 POST
FOLLOW
How do you access the rear tail lamp bulbs for replacement and also the right front side panel turn signal bulb?
May 14, 2009 at 10:09 AM
CERTIFIED EXPERT
Open the trunk and remove the carpet from near the tail light assembly. Under that you will find a few wing nuts that hold the assembly in place. Remove them, remove the asselbly and you will have access to the bulbs.
Apr 16, 2010 at 12:26 PM
CERTIFIED EXPERT
Open the trunk and remove the carpet from near the tail light assembly. Under that you will find a few wing nuts that hold the assembly in place. Remove them, remove the asselbly and you will have access to the bulbs. As far as the side marker on the front, if you can't remove the outer cover, access it either through the inner fender, from under the car, or under the hood.
