After replacing the solenoids, I disconnected both the negative and positive battery terminals. Once the job was complete, I reconnected everything and started the car. It ran great, and I tested the manual gear selection, which had not worked previously, but now it did.
I took the car for a test drive, shifting smoothly through all gears, including 5th gear, with no issues. After returning home, I checked the transmission fluid, which appeared to be within the proper specifications according to the dipstick chart.
However, after pulling out of the driveway and shifting into park, the check engine light came on. Now, the same code and issue have returned, with the car not shifting out of first gear
Feb 20, 2025 at 2:22 PM
