PO720 Speed Output Sensor Code - Check Engine Light
2009 FORD CROWN VICTORIA
108,000 MILES
CHRIS3558
  • 9 POSTS
I just purchased a '09 Crown Vic P71 Police car from a state auction. The check engine light code shows a PO720 (Speed Output Sensor). I have checked the transmission fluid and it does not smell burnt and is up to the proper level. The transmission has a delay to shift into drive, it does go down the highway ok. Also, the cruise control does work as well as the speedo and the mileage. I would like to replace the speed output sensor on the transmission. Problem is, there is very little room to get your hand up there. What is the trick in R&R this sensor with the trans in place?
Just a FYI, since this is a former police car, is there any police circuits that would be used in the speed output circuit? Is there a fuse for this circuit, if so what # fuse should I be checking? Any help would be much appreciated.
Thanks,
Chris
May 18, 2013 at 11:25 AM
nothing special due to police version.
the sensor is tight but if you drop the crossmember, and lower the rear of the trans, it gives you the needed room to remove it.
May 18, 2013 at 11:47 AM
CHRIS3558
  • 9 POSTS
Please read the beginning post. Back to the original problem. I replaced the speed output sensor and test drove the car, no change. When going from park or neutrel to drive, there is about a 5 second delay. It goes into reverse ok. It seems to drive down the road ok, but going from 50 mph to say 20, when it down shifts and you start to excellerate the motor revvs up as if the trans is slipping, then all of a sudden it locks into gear and goes??? Any ideas before I go to the Ford garage?
Thanks,
Chris
May 25, 2013 at 4:51 AM
TMGWASHERE
Im having same problem with my 07 crown vic pi you ever fimd a fix? New torque converter maybe?
Sep 21, 2014 at 6:39 PM
CHRIS3558
  • 9 POSTS
I found a decent tranny shop and had them tear into it. It ended up being one of the steel rings had broke and damaged the case beyond repair. I had to get a used case and had my internals put back in it along with a rebuild. When the police dept. owned it, apparently the car had gotten stuck and the doorknob behind the wheel was going from forward to reverse many times and this caused the ring to break. Then the car went to the auction and I was the lucky guy to buy it!
Sep 21, 2014 at 6:47 PM
