Already replaced the purge valve and also the vent valve. put a hundred miles on it pop back on again. I know I'm looking at the filler neck which looks like it has moisture areas from gas leaking. have you guys ever heard of anything from these filler necks? because this is looking kind of crummy to me. I do not have access to a smoke machine and as I've said in the past I am a dealership tech that is retired 35 years of twisting wrenches. so I have a fair idea of what I'm doing. the gas cap has also been changed with a factory OEM cap as I said then they're done. this I just wanted to know if you guys have any more input on this if the purge canister the saint known for cracking or if there is a problem with these next rotting and putting? especially underneath the flexible area where the hose goes to connect the two next the one from the tank to the one to the body. please get back to me as soon as possible and let me know. I would appreciate any input on this subject. thank you, AJ from AJ customs
Nov 16, 2019 at 1:37 PM
