Hello, what sub model is the Fuso? FE125, fe145, fe180, fg140, etc.? I do not see any 3.0liters listed. We actually don't have any information listed on this vehicle here in the US. But if you have a loss of power and an EGR code. It sounds like the EGR valve is stuck open. Try unbolting the EGR valve and make sure there is no carbon build up holding the pintle open. I will try to find a picture of the valve for this vehicle, but that that's where you should start. Even a small piece of carbon can hold the valve open, allowing exhaust gases into the intake manifold all the time when it's only supposed to open under heavy throttle.
This is a picture of the valve; I hope this is the correct one. The code criteria state the ECM (engine computer) is reading an improper voltage through the valve. So, this may be a faulty valve.
This type of valve uses stepper motors to control it. A stepper motor has 2 sets of windings internal and 4 wires, 2 wires control each winding to move the valve in or out as needed.
If this is the valve you have on your vehicle, it should be a 4-pin plug on the valve, if so, you can check the resistance across the 2 windings with the valve unplugged to check if one of the stepper motors windings has lower or higher resistance than the other. Unfortunately, since this vehicle is not sold here in the US, we have limited to no information on it.
Dec 1, 2022 at 10:03 AM
