Code Po304
2007 SATURN VUE
198,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
MAMADETTE4
Replaced coil on cylinder 4. put new spark plugs in it. then we were getting the misfire for cylinder 1, 2, and 4. drove it a little more than only got the misfire on cylinder 4. What could be causing this? It is driving my other half crazy.
Nov 3, 2021 at 10:10 PM
Good morning,
The first thing I would do is check the compression to be sure the engine is good.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Then I would test the fuel pressure. You need to be sure sufficient fuel is getting to the cylinders.
Fuel Pressure (Key ON, Engine OFF) .................... 330-382 kPa (48-56 psi)
Nov 4, 2021 at 2:35 AM
