Okay, i have replaced the ignition manifold i have replaced the coil for spark plugs 1 and 4. i have put all new spark plugs and boots on car also have replaced the pulley tensioner. i have cleaned out the EGR valve and gasket i have got a brand new air filter in the car. Now the check engine light is on and flashing the whole time and the repair manual tells me if my check engine light is on and flashing giving me a p0300 code when hooked up to the obd II meaning i have a misfire somewhere that's why i replaced the coil ,boots, and spark plugs. I can drive the car but just for me to go over the overpass a very slight incline the car will maybe only go 10 miles per hour and that's with the gas pedal floored all the way to the floor it also hesitates when it is shifting from one gear to the next. so it's taking about a minute and a half or more to switch gears to basically engage at all. i need to know the exact cause of problem to be able to fix it. i don't have the funds to replace things that will nor fix the problem as i'm not made of money. i need my car to run properly as i'm disabled and this is my only form of transportation for myself. please help me someone give me a real diagnose of the cars issue at hand. Thanks Ida Walster of Lakewood, WA.
Sep 17, 2021 at 8:36 AM
