I have change spark plugs, checked coils and they are good. also changed wires.I even checked for vacuum leaks and found none.I hooked up the vacuum gauge and it reads 15hg steady.I also found that when under a load the engine is lacking power.Fuel pressure is at 44 psi and it has a new filter and fuel pump.What would cause the lack of power and low vacuum reading?
Dec 27, 2019 at 3:49 PM
