I put new spark plugs,wires and cap in and new rotor button, still has a miss. When i hook up the scan tool it shows only cylinder 1 misfiring. I changed the spark because in thought i might have gotten a bad one, still the same. I checked all vacuum lines and no leak, also the check engine light blinks off and on. I will check the fuel pressure to see if it is good. If the fuel pressure is good what else would cause this?
Jan 5, 2021 at 3:00 PM
