P0299 code do you think something is blocked due to injector cleaner?
2010 FORD FIESTA
130,000 MILES
ASHLEY LLOYD
Hi, about 3 weeks ago I put injector cleaner in my car and basically hasn’t been same since as the next day engine light came on. I have waited for all the fuel to go and refilled tank with diesel and car still isn’t the same. basically when I’m on motorways going up hill the car will go into limp mode but after I knock engine off all power will come back. I’ve just put a diagnostic reader and had code po299. do you think something is blocked due to injector cleaner? Thanks
Aug 13, 2020 at 7:36 AM
This code says that the turbo on this engine is not able to provide sufficient air to create the boost that is needed. So, it is considered an under-boost condition, and this could be caused by a number of things like a faulty boost sensor but the most common cause of this is excessive soot build up in the intake system.
So that means we should remove the intake and look for carbon build up in the throttle body coming from the turbo.
You can clean this, but the ultimate solution is to find why you have excessive soot. This is coming from the exhaust side of the turbo and entering through the EGR valve.
So, we need to remove the EGR and inspect for soot as well. If you, have it here, then you more than likely will need to replace the valve and then clean the entire EGR system.
Next, we need to find where the soot is coming from which is most likely damaged injectors. Basically, what happens is the fuel system gets contaminated and damages the injectors and they end up over fueling the engine which produces more soot. So, using an injector cleaner is a good idea but if the soot continues to build then you most likely will need to replace the injectors.
We don't have a manual on this specific vehicle, so I don't have the detail for it but more than likely we are going to have to replace the injectors, clean the fuel system, replace the fuel filter, and then clean the EGR system and replace the valve if needed.
Once this all happens you will no longer get this code and then you will just need to make sure to change your fuel filters on regulator basis so that this doesn't happen again.
Apr 22, 2022 at 7:36 AM
FLOYDKINTY
DataFast Proxies | IPv6 Proxy for XEvil | Solver reCAPTCHA
Definitive Solution in IPv6 Proxy!
Anonymous IPv6 Proxy, undetectable on L2 and L3 Layers of the OSI model,
100% no DNS leak, no Header leak.
- Anonymous IPv6 proxy
- Undetectable IPv6 Proxy
- High Speed IPv6 Proxy
- Highest Quality IPv6 Proxy
- Virgin IPv6 proxy
- Dedicated IPv6 Proxy
- Rotating IPv6 Proxy
https://datafastproxies.com/
Sep 22, 2022 at 5:01 PM
I noticed it has been a couple of days since we heard from you. By chance, have you been able to make any progress? We are interested in knowing.
Sep 24, 2022 at 10:20 PM
LUCAPBEICT
acura nsx 2016 price phoenix az
Feb 10, 2023 at 7:54 AM
JOKA ROOM APP
  • 0 POST
jokaroom news https://t.me/jokaroomvip
Mar 27, 2023 at 6:10 PM
ELCENUB
  • 0 POST
Counter Strike 1.6 - The reasons nobody never uninstalls
CS 1.6 is the most recognized and most played multiplayer FPS since it came out. The game is being played in every landscape of the world. Definitely in, every gaming zone, on every Pcs and Laptop and even on all Xbox machine.
CS 1.6:
Counter Strike 1.6 started as a modification of the Half-life game which had already been published in the late 90's. This first person shooter game is a tactical and skill based game which tests the brain and responsive skills of the player. Valve LLC took the reins of making this FPS in the year 2000, upgraded it by adding some new challenging and epic metrics to CS.
Definitely the best features of Counter Strike Source is the permission to setup your own server. This means a whole new multiverse for hobbiests to setup group server and unite. With such a feature available to them the fun is limitless. Around launch time users had to use Dedicated Servers to run their Counter Strike Global Offensive Servers. In this day in age clans use a 2400G VPS and always have stable performance in Counter Strike 1.6.
Counter Strike GO has been a source of entertainment for the players since its inception. The question is how? Well, it is because it is that kind of shooter which rarely actually get slow even if one plays it for years.
Here are some of the reasons why CS Source is entertaining:
One can simply never get tired of the game since it allows the gamers to change it according to their experience and preferences. One of the main problems of this freedom is called "wallhacking". Legit CSGO Cheats are the most funny part of MMO shooters and all of the teams have actually become the hackers by the time they're great at CS. Some may want to play the game on the original levels and the maps with which they are used to but the truth is that most of the top-tier users just want some different things to increase their interest in CS. LeagueCheats cheats works on WarGods, WarGodz, sXe injected, Esportal, GamersClub, EAC, Challengeme.gg, 99damage, FaceIT, SoStronk, PVPRO, GOLeague, ChallengerMode, FastCup CSGO, Akros, VAC, VACNET, Gfinity, CEVO, ESL, FaceIT Server Side, SourceMod Anti cheat, KAC, PopFlash, Kickback, and ZenGaming. Legit CSGO Hacks
So, groups can create many maps for their own style or for their leased servers. Isn't it amazing that you play every match on many different maps and then teams attempt to get experience with that particular map by practicing repeatedly via epic fights. This in my POV is the main reason why people will ever quits even after a multitude of seasons.
The levels can be created through various programs and software, which are completely free to use and one can be proficient in it by watching Video tutorials. Most people believe that Counter Strike 1.6 came with hundreds of maps but the point is that it came only with some simple maps but over time the modders created some new distinct maps on the Valve mapping platform which the users have been installing them via various websites.
Another idea which is keeping CS CZ fresh and exciting is the feature to make your own servers. One can make a separate root for their own clans so that they can have some epic battles with each other or they can invite other clans for a PCW. As initially mentioned a player can have a AMD VPS and surely will have good performance in CS 1.6.
Also, there are also many interesting spray logos available which the users can create and can spray them on the walls or anything else ingame. The spray logos actually show the hold of the particular players or clans.
In other terms customizing CS Condition Zero was never so easy before. Now one can never get used to this iconic first person shooter game.
Also, any and all the shooters that have various modes can have several features that always provide the users with noteworthy moments spent gaming on the gaming computer. Whether you are a little one or already a grown up it is impossible not to have played Counter Strike GO one time.
Counter Strike S Hacks & How VPS AMD Affects it. bc1c6a9
Jun 24, 2023 at 2:38 PM
