The code indicates the MAP (manifold absolute pressure sensor) signal is higher than it should be. There are a few things that can cause this code.
First, make sure there are no engine vacuum leaks. Specifically check the PCV hose to make sure it is connected and not cracked and leaking.
If that checks out good, then we need to jump into some diagnostics. I attached them below. Note, they diagnostics indicate the need for a scan tool that can communicate with the vehicle.
Take a look through the diagnostics and let me know if you have questions or if you feel comfortable performing them. If not or if you don't have the scan tool, you may want to consider replacing the MAP sensor. It could have failed.
Here is a link that explains how to locate an engine vacuum leak:
Also, I attached a picture below (last pic) showing the PCV and PCV hose. Make sure it isn't broken.
Let me know what you find.
See pics below.
Sep 7, 2024 at 7:00 PM
