Code Po181
2006 NISSAN ALTIMA
90,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
KATIE DIXON
The service engine light is on. It is the fuel temperature sensor. Will it go out when temperature outside warms up been extremely cold since it came on?
Jan 2, 2018 at 6:47 AM
CARADIODOC
  • 34,306 POSTS
P0181 - Fuel temperature sensor a circuit range/performance.
Diagnostic fault codes never say to replace a part or that one is bad. They only indicate the circuit or system that needs further diagnosis. Normally when a part is referenced in a fault code, it is actually the cause of that code about half of the time, but temperature sensors have an extremely low failure rate because there is just one component inside them. While it is always possible for a temperature sensor to fail, it is much more likely you are going to find a wiring or connector terminal problem.
Jan 2, 2018 at 6:42 PM
