Okay, there's a few possibilities. A stuck lean oxygen sensor, meaning stuck low voltage .500-.100 millivolts, a non functional oxygen sensor heater circuit, a bad fuel pressure regulator, a sticking open fuel injector, or a bad catalytic converter. Any of these are a possibility with the mileage your car has. The oxygen sensor can be tested with multi-meter, if it's a 4 wire sensor, the 2 white wires are the heater circuit and should read 12volts. The other 2 wires are high and low sensor signal. One of these wires will having a fluctuating voltage signal from .1 to .9 millivolts. A lot of times, and this probably the issue, these sensors get stuck below .5 millivolts telling the ECM that the exhaust is lean causing the engine to go rich. Checking the fuel pressure regulator will require a fuel pressure gauge. But if you have a scan tool that can read live data, it will be much easier to see what the sensors are doing. The car should be scanned for diagnostic trouble codes first.
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Now if the car is running lean, due to a bad intake manifold gasket, a vacuum leak (broken hose), a clogged fuel filter, a stuck oxygen sensor, the oxygen sensor is reading .5 to .9 millivolts the ecm seeing a rich signal sends the engine lean to compensate.
With the mileage you have, you're car is due for new oxygen sensors anyway at this point. But the car should be diagnosed instead of just replacing parts.
Dec 22, 2019 at 3:45 AM
