Running engine with only timing belt
PLYMOUTH VOYAGER
RADEYB
My dad and I just tore apart our 1997 Plymouth Voyager's engine and rebuilt it, but now we have an oil leak we can't track down. He'd like to run the engine without any belts on it except for the timing belt, but isn't sure that that's possible - he thinks we might need to make sure the generator is hooked up to power certain components, but it's also possible the battery can power everything for a couple minutes.
Long story short - is the timing belt the only critical belt for the operation of the engine? We'd like to take as much off the engine as possible to get a good look at what's going on in there.
Aug 31, 2007 at 10:33 PM
MERLIN2021
  • 17,250 POSTS
My opinion is that if you have an oil leak you can run the engine for a few mins with a good battery. Just be careful were you place the back of the alternator when you lay it down!
Sep 1, 2007 at 8:07 AM
