Plymouth Voyager vibrating and shimmy in front end right si
PLYMOUTH VOYAGER
JCM1964
Suspension problem
Plymouth Voyager 6 cyl Front Wheel Drive Automatic 105000 miles
I have a shimmy starting off when accelerating, feels like it shimmys left to right, and steering wheel will do the same. Then goes away at higher speed to a vibration. The shimmy will ease off and go away when I let off the accelerator and come back when applied. I am suspecting cv axels? I pulled the right side wheel off and shook the disc back and forth foward and back there seem to be a little play, with the entire axel, I am not sure if there is supposed to be any play at all. Any help from a pro will be appreaciated thank you
Jan 19, 2008 at 8:00 AM
LEGITIMATE007
  • 5,121 POSTS
several things: make sure your tires are balance correctly along with the front end alignment. also make sure that your rotors aren't warped
Jan 19, 2008 at 8:56 AM
