[quote:83c5542c02="happyman"]I have a 1996 Plymouth voyager 3.0 L and the engine is reving high, how do i fix this.[/quote:83c5542c02]
WOW!!!!!!!
This is as hard as it gets...no doubt!!!
Happyman, i'm going to try my best to help you.
A High idle may be cause by many many things.
With the information you provided, i'm not sure if i can assist you well but i'll try. Pop the hood & start to look around for broken vaccum hoses. If you find one, replace it. Do you have a warning light on the dash (ie: ck engine light). Are your brakes working efficiently. Is the Engine running smooth?
Mr. Happyman sir, i belive you might have a serious or dangerous situation with your van. You might want to bring it to your local repair shop to have it looked at!!!!
GOOD LUCK!!!!!!!!!
Oct 6, 2007 at 7:10 PM
