Engine codes
PLYMOUTH VOYAGER
96VOYAGER
I have a 96 Plymouth Voyager 57,000 miles. The van started stumbling about two days ago randomly and then today it acted as if it was going to run out of fuel.(It had plenty) Almost not making it up a small hill. Thats when the "Service Engine Soon" light came on. Here are the codes I got from it. 12, and 43. The 12 is a battery disconect code. but the 43 said it was either a cylinder misfire or a problem in power module to logic module interface.(Whatever that means) Where do I start to look for the problem?
Mar 14, 2006 at 7:44 PM
CHADWINKLER5066
check fuel filter and pump... had the same thing happen.... replaced pump and filter mine ( all in one unit) works great. get a fuel pressure gauge about 25 bulks at any auto parts store and start with that..... vehicles with fuel injection require a constant fuel pressure and the slightest loss can cause the problems you are having good luck
[quote:623e686b3a="96voyager"]I have a 96 Plymouth Voyager 57,000 miles. The van started stumbling about two days ago randomly and then today it acted as if it was going to run out of fuel.(It had plenty) Almost not making it up a small hill. Thats when the "Service Engine Soon" light came on. Here are the codes I got from it. 12, and 43. The 12 is a battery disconect code. but the 43 said it was either a cylinder misfire or a problem in power module to logic module interface.(Whatever that means) Where do I start to look for the problem?[/quote:623e686b3a]
Mar 15, 2006 at 8:45 PM
