electrical problems
PLYMOUTH VOYAGER
CLEMENTINE
I have a '95 plymouth voyager with 186000 miles on a 3.0 litre engine. The problem is the headlamps, hazards and brake lights are not working. When the button for the headlamps is turned on the brake switch buzzes and continues to buzz until the brake is depressed. The fuses all appear to be fine. I replaced the brake switch and brake lights worked on the first test, but upon testing again just a couple hours later they did not work. I just spent 500.00 for a new waterpump and timing belt. I hate to think it was a waste. I was hoping to get 200000 miles. It runs really well, but it is useless in this condition.
Mar 25, 2007 at 5:22 PM
MERLIN2021
  • 17,250 POSTS
Two things maybe! Look at all the grounds for the body...check the taillghts to see if the right types are installed? Dual filaments as needed, and sigles as needed...in the right pigtails!
Mar 27, 2007 at 2:23 PM
