Camber
PLYMOUTH VOYAGER
STRANGE1
I have 1993 Plymouth Grand Voyager LE w/ABS, 3.3 engine and a mileage of about 132K.. Am in process of replacing the left axle assy. Having trouble removing hub assy. have loosing the nut to the bottom ball joint but not removed the joint. Have lossened the two bolts attaching hub to strutt. Won't this change the camber? How do I readjust the camber? also do I need to take the bottom ball joint out of the clamp and do I need to remove the outer tierod end? Thanks.
Jack
May 17, 2007 at 2:46 PM
BOOTDOG
  • 665 POSTS
yes you will need to realign the vehicle after loosening the strut. all you needed to do is remove the ball joint stud and tie rod end from the knuckle, and remove the axle nut. use a long pry bar or pipe etc. to pry the lower control arm from the knuckle. by doing it this way, you won't need to realign. either way will work, you still need to remove the tie rod end also. hope this helps
May 19, 2007 at 4:06 PM
