Battery cables
PLYMOUTH VOYAGER
OTLEWSKI24
97 Plymouth grand voyager. Van started before the replacement of cables. I removed the original cables taking the neg cable off the 2 grounds? and clipping the wire that goes to the pcm. Now the van wont start with the new cables in. Was that wire important? And is there a way to cure this problem?
Sep 12, 2007 at 1:26 PM
SERVICE WRITER
  • 9,123 POSTS
Does it crank at all, or just not start?
Are the wires you replaced them with the same in cluding the clipped wire?
Motor size?
Sep 12, 2007 at 3:28 PM
