Hi dismas,
Thank you for the donation.
Here are procedures for removing the windshield washer tank with motor.
WINDSHIELD WASHER BOTTLE
Removal & Installation
1 . Disconnect and isolate the negative battery cable.
2 . Suitably support vehicle on safety stands.
3 . Remove right front wheel.
4 . Remove front wheelhouse splash shield.
5 . Disconnect connectors from the front windshield and rear window washer pumps, the fluid level sensor, and the rear washer hose. See Fig. 15 .
6 . If washer bottle has fluid in it place a suitable drain pan under the hose connections.
7 . Disconnect front washer hose at front wiper unit in the engine compartment. See Fig. 16 .
8 . The front hose will be removed with the bottle. Allow washer bottle to drain.
9 . Remove screws holding washer bottle to front fender support and remove bottle.
10 . To install, reverse removal procedures.
Nov 15, 2009 at 12:44 PM
