2000 Plymouth Voyager RPM levels
2000 PLYMOUTH VOYAGER
217,000 MILES • 6 CYL • FWD • AUTOMATIC
LEEJEWELL
What would cause the rpm level of my vehicle to run higher than normal level when driving?
Could it be a low level of transmission fluid or what other thing could I check?
Jan 14, 2010 at 7:36 AM
CARADIODOC
  • 34,306 POSTS
Not sure how you could relate an engine problem to the transmission. Start by looking for a vacuum leak. This could be a disconnected or brittle / broken / cracked rubber or plastic hose, but more commonly a cracked intake manifold gasket. You might find it by squirting water around the gaskets while the engine is running and still cold. The vacuum leak will suck the water in and the engine speed will slow down.
caradiodoc
Jan 16, 2010 at 5:47 AM
