FUEL FILTER
Removal & Installation
Fuel filter is located on top of fuel tank, near fuel pump module. Fuel lines are permanently attached to fuel filter.
Release fuel pressure from fuel system.
Disconnect fuel lines at fuel pump module and fuel supply line using proper procedure. Remove retaining bolt and fuel filter.
To install, reverse removal procedure. Use proper procedure for installing fuel lines. Turn ignition on and check for fuel leaks.
Nov 11, 2008 at 3:15 PM
