2000 Plymouth Voyager check engine lite
2000 PLYMOUTH VOYAGER
116,000 MILES • 6 CYL • FWD • AUTOMATIC
KINGPIN1952
I have brought my plymouth to 3 garages because the check engine lite is on and I can not get a inspection sticker . no one can get the scanner to communicate with the computer. they have checked for a blown fuse and have not found one.everything electiric is working except the speedominator.the van is running fine no problems
Nov 1, 2009 at 3:47 PM
BMRFIXIT
  • 19,053 POSTS
Did you get a rejection sticker
if so was it because of no communication or because check engine light on and have codes
did they try to get the codes by cycling the key on off on off on
and read codes in the odometer area
I would suspect no buss code and the cluster need to be repaired
most common is that the cluster connector pins need to be re solder to the board
and if so and to do that have to remove cluster and take apart and solder the pins back onto the board
Nov 2, 2009 at 6:07 AM
KINGPIN1952
how expensive is it to have this repaired how long to repair
Nov 2, 2009 at 7:24 AM
BMRFIXIT
  • 19,053 POSTS
Its about $100 to $150 to have a tech do the work for you
Nov 2, 2009 at 4:23 PM
KINGPIN1952
thanks for your help hope I can find a tech that will do it for me
Nov 3, 2009 at 7:33 AM
