1999 Plymouth Voyager will not stay running
1999 PLYMOUTH VOYAGER
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
ERICA4508
I have put a new fuel pump, fuel filter, idol pos sensor, map sensor, air filter, checked the injectors, new plugs and wires, had the timeing checked, cleaned out the throttle boddy, checked all of the vacume hoses checked the compression and i am at a loss. it will start sometimes, when it does you can smell gas like it is fluding and if you let up on the gas or put it into any gear besides park and neutral it will die out. I am out of money and luck to put into it Please help any way that you can
Jun 11, 2009 at 7:46 PM
BMRFIXIT
  • 19,053 POSTS
Do a compression test
had a similar issue turn out to be a jumped timing belt
have it checked again it can be easily over looked
also check for codes cycle key on off on off on read codes in odometer area
good luck
let me know
Jun 13, 2009 at 6:47 AM
