1999 Plymouth Voyager Oil light come on
1999 PLYMOUTH VOYAGER
GRADER MAN
Engine Mechanical problem
1999 Plymouth Voyager 4 cyl Two Wheel Drive 168700 miles
While driving down the road & get on gas oil light come on. When get back on gas light goes off. It don't come on while idling. Can get on & off gas while idling light don't come on. I took the oil screen off. I thought it might be clogged up. It was clean & open. I clean it any way & put it back on. I put a new oil pressure switch , new sparks plugs, & plugs wires on it. It still come on when get off gas while driving. I use H avoline 30HD oil in it. Any suggestion? Thank you.
Jun 14, 2008 at 3:39 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:215f346fe7="grader man"]Engine Mechanical problem
While driving down the road & get on gas oil light come on. When get back on gas light goes off. It don't come on while idling. Can get on & off gas while idling light don't come on. I took the oil screen off. I thought it might be clogged up. It was clean & open. I clean it any way & put it back on. I put a new oil pressure switch , new sparks plugs, & plugs wires on it. It still come on when get off gas while driving. I use H avoline 30HD oil in it. Any suggestion? Thank you.[/quote:215f346fe7]
May I ask why you use a 30 wieght Heavy Duty Oil in your vehicle. And how long have you been using it. Most newer vehicles recommend either a 10w30, 5w20 or 5w30.
Have you checked the Oil Pressure?
Jun 16, 2008 at 7:54 PM
GRADER MAN
I brought the van in Feburary this year. I haven' drove the van to much since I brought. I change the oil & filter after I brought it. I have always use Havoline 30 HD oil in all my autos.
Jun 16, 2008 at 8:25 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:7fe0ae8a0b="grader man"]I brought the van in Feburary this year. I haven' drove the van to much since I brought. I change the oil & filter after I brought it. I have always use Havoline 30 HD oil in all my autos.[/quote:7fe0ae8a0b]
OK, was just wondering.
Have you checked the oil pressure?
Also check the Wiring on the pressure switch.
Jun 16, 2008 at 9:07 PM
