1999 Plymouth Voyager headlights
1999 PLYMOUTH VOYAGER
BIGRUSS80
Electrical problem
1999 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
when my high beams are on my right headlight goes out but when i turn off the high beams the right headlight stays off and the high beam light stays on but very dim.. what could be the problem.
Feb 16, 2010 at 7:52 PM
CARADIODOC
  • 34,306 POSTS
If it's dim, how do you know it's the high beam staying on? This sounds typical of a bad ground. Wiggle the bulb's connector. If you see a change, suspect corroded terminals in the connector. If there is no change, follow the wiring harness back until you find the ground wire. Check for a loose or corroded connection where it's bolted to the body.
caradiodoc
Feb 21, 2010 at 8:51 AM
