1999 Plymouth Voyager Fan only works on high
1999 PLYMOUTH VOYAGER
150,000 MILES • 6 CYL • FWD • AUTOMATIC
MADEST8
  • 4 POSTS
My heating/air conditioning fan has been working fine and never had any problems. The other day, coming home, I turned down the air and it stopped working. It will only work on High. What could the problem be and how can I fix it?
Jul 28, 2008 at 3:50 PM
DOCFIXIT
  • 18,828 POSTS
blower motor resistor located to left of blower motor behind glove box.
Jul 28, 2008 at 4:03 PM
MADEST8
  • 4 POSTS
Ok...what do I have to do to fix it? I am certainly not automotive repair illiterate but I am also by no means a mechanic. Suggestions on a good manual? Anyone know how expensive it would be to take it somewhere to get it fixed?
Jul 29, 2008 at 10:02 AM
DOCFIXIT
  • 18,828 POSTS
The part is less than $15 you probably be charged 1 hr. labor. I don't your areas rate here it is $90
It is just behind the glove box like I told you 2screws hold it on . Just drop the glove box down and there it is .or come up from under dash pass side.
Jul 29, 2008 at 10:37 AM
MADEST8
  • 4 POSTS
Thanks-a-bunch!
Jul 29, 2008 at 11:42 AM
