1999 Plymouth Voyager 1999 Plymouth Voyager Noise Problem s
1999 PLYMOUTH VOYAGER
DAVIDB
Suspension problem
1999 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 120K miles
It was the Passenger side shock mount bolt. One was bent and loose. I replaced the shocks anyway because it needed it. Simple enough. Ive done shocks 3 times. I've never replaced front struts before though, and that will have to be done immediately. I should be able to get instructions from the guys at Autozone, But Any tips would be appreciated. Thanks Carpros, money well spent.
Oct 26, 2008 at 6:21 PM
Hi:
Replacing struts is much more involved. If you don't have the proper tools, it can actually be dangerous. You will need a coil spring compressor.
Let me know if I can help.
Nov 5, 2008 at 10:50 AM
