1998 Plymouth Voyager wipers won't turn off
1998 PLYMOUTH VOYAGER
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
TDW100
  • 4 POSTS
When I turn on my windshield wipers, then turn them off, they won't turn off immediately. In fact, they stay running for maybe 20 minutes. I have tried replacing the switch (on the steering column) and the wiper motor itself to no avail. I have tested the on/off relay and high/low relay. They are working fine. I am thinking it is the BCM, but have no idea how to 1) find it, or 2) verify if it is faulty or not.
Any ideas?
Jul 31, 2010 at 11:29 AM
KHLOW2008
  • 41,814 POSTS
Hi tdw100,
Thank you for the donation.
To test the BCM, appropriate scan tools would be required.
I have sent the diagnostic files to you. BCM location is shown.
Jul 31, 2010 at 11:53 AM
TDW100
  • 4 POSTS
In your reply, you state that "the appropriate scan tool is required". Can you tell me exactly what scan tool is required so I can determine if I will go buy one or not.
Thanks,
Tom
Jul 31, 2010 at 1:55 PM
KHLOW2008
  • 41,814 POSTS
Generic scan tools an be used but it might not be able to perform all necessary test functions. To be fully compatible, it should be equivalent to Chrysler Diagnostic Readout Box.
Jul 31, 2010 at 2:11 PM
TDW100
  • 4 POSTS
Everything is clear down to step 4. Resistance from Wiper On Relay terminal C to ground is open (infinite resistance). This step tells me that the problem is the BCM.
Can you explain to me why this tells me the BCM is bad? What is the resistance from this terminal to ground supposed to be?
Nearly done. Thanks!
Jul 31, 2010 at 3:19 PM
KHLOW2008
  • 41,814 POSTS
From the steps, it does not indicate the BCM is bad. The resistance should be below 100 ohms, but did not indicate if it should be open, which you mentioned is infinity, indicating open circuit. For this you should be checking the wiper ON relay control circuit.
If resiatance is 100 ohms or more, the BCM has internal fault, possibly some part is not working correctly due to high resistance.
Go through Step 5 and see if there is any problem.
Jul 31, 2010 at 11:04 PM
TDW100
  • 4 POSTS
Could you tell me where the wiper on relay circuit is? The picture in the original documents you sent me point to some location that isn't clear to me.
Thank you,
Tom
Aug 2, 2010 at 9:51 AM
KHLOW2008
  • 41,814 POSTS
It is in the PDC, Power Distribution Center.
https://www.2carpros.com/forum/automotive_pictures/192750_PDC98VoyagerFig02_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_PDC98VoyagerFig04_1.jpg
Aug 2, 2010 at 11:48 AM
