This problem occured before the tune up. I was hoping the tune up would fix the problem. There is no Engine service light on, still got the codes from the computer which showed no problems.
The engine will idle fine but as soon as you put it into gear it begins to stall. I can however stomp on the gas to keep it running, but I don't think that is the safest solution.
Any help would be great.
Apr 16, 2009 at 8:37 AM
