1998 Plymouth Voyager reverse lights
1998 PLYMOUTH VOYAGER
174,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRSTMAY
I noticed that both of my reverse lights are not working. My husband toke the taillights apart to examine the light bulbs. The lights looked fine. My husband then went to check the fuse, but we can not figure out what fuse goes to the reverse lights, where the fuse is, or if we are dealing with something totally differant? Thank you for you time and help. mrstmay
Oct 13, 2008 at 5:13 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would be thinking that your problem is the reverse light switch on the transmission check this out first.
Mark (mhpautos)
Oct 13, 2008 at 5:15 PM
MRSTMAY
How do I find out if it is that switch?,..where exactly is the switch , and how hard is it to fix the problem?
Oct 13, 2008 at 5:30 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
i will try and locate a pic for you, to check the switch you will just have to unplug it and bridge the electrical terminals with a split pin or paper clip, with the ignition on and if the lights come on the switch will be faulty, now i wont get access to the data base for a few hrs as i am in Aust and i am at work just now, i need to be logged on at home, so i will do this this evening.
Mark (mhpautos)
Oct 13, 2008 at 5:39 PM
MRSTMAY
I appreciate you help and time.
Robin M-Tennessee-USA
Oct 13, 2008 at 5:48 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, I am fairly sure that this will be your application, if not please let me know and i will look into it further. Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_22.jpg
Oct 14, 2008 at 4:24 AM
