1998 Plymouth Voyager no brake lights
1998 PLYMOUTH VOYAGER
300,000 MILES • 4 CYL • FWD • AUTOMATIC
RYANTURG
hello i have no brake lights the bulbs are still good but they do nothing when you press on the brakes i would appreciate any suggestions
Dec 20, 2009 at 12:12 PM
JDL
  • 16,098 POSTS
Welcome to the forum, check fuse 13-- 20 amp in power distribution center, under the hood. Not only check fuse, use a testlite on the fuse circuit, it should be hot all the time. Next, I'd check the circuits at the stop lamp switch. Possible issue with stop lamp switch?
Dec 20, 2009 at 1:14 PM
