1998 Plymouth Voyager leaks coolant
1998 PLYMOUTH VOYAGER
MAMAELEPHANT1
Engine Cooling problem
1998 Plymouth Voyager 6 cyl 122000 miles
it only leaks coolant after i've been out running around. i check in the parking lots and never see any leak then i will come home and it seems to leak after it cools off also going down the highway about 55 it will like hiccup the speedometor will drop to 0 then back up real fast what can cause any of this i only bought this van 6 months ago
Dec 15, 2009 at 2:18 PM
The reason you notice the leak after the car is shut down is because for a short period of time, the engine is still at normal operating temp and when you shut the engine, the coolant lays in the engine block and gets hotter which builds pressure even higher.
What I need you to do is place a piece of cardboard under the vehicle when you park it. THen let me know aprox where it is leaking from. If I had to guess, I would say it will be on the passanger side.
Let me know. Also, as far as the speedo, you may have a vehicle speed sensor going bad. Has the check engine light come on?
Jan 4, 2010 at 3:33 PM
